Guest nx2000de Posted May 29, 2007 Share Posted May 29, 2007 would it be a smart move to just keep the stock springs and rock out some tokico illuminas? I'm not going be at any SCCA events just a little spirited driving from time to time. I just need your guys opinion.. Thanks. Quote Link to comment Share on other sites More sharing options...
evildky Posted May 29, 2007 Share Posted May 29, 2007 it won't hurt anything, the main draw for aftermarket springs is to lower the ride height, I's still highly recomend a fat front swap bar if you intend to autocross, and you'll still be stock class legal Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted May 29, 2007 Share Posted May 29, 2007 Springs do wear out. If your springs are original issue, then as long as you are doing struts you may want to spring for a new set (Get it? "spring" for a new set?) Lots of places sell replacement springs that fit the stock perches. You may want to spring for a set that is slightly stiffer than the stock units. Quote Link to comment Share on other sites More sharing options...
