Grounds are important
ZR8ED
I was doing some work on the Z the last two days. I had my front left turn signal doing strange things.
It would light up with the running lights.
It would flash when i turned on the left signal
BUT when it flashed, it flashed OFF. It did not flash and get brighter (it should flash and get brighter)
I cleaned all the connections. Didn't fix.
I checked for power all the way to the bulb connector. still no good.
I then tried the right side connector. It didn't work properly either.
Ok so the wiring on the car was messed up?
I ASSUMED the ground was good because the light would still light as needed either for signalling or parking lights. WRONG!!!!
Lots more tinkering, and discovered the ground was not good ENOUGH. I poprivited a small blade connector directly to the bulb holder chassis, and attached a fresh groundwire, and wired it to the body.
Light works normally!
Warning. Do not assume you have a good ground, just because you have a ground.
Whew. Another "assumption" lesson.
Scott.
