ZR8ED Posted June 5, 2007 Share Posted June 5, 2007 Just venting I suppose. Pulled car in garage. Running nicely. Turn off engine. Fix left front turn signal ground. Move SAFC control panel temporarily from glove box to centre console for easy adjustments. Start car to move out of garage. Runs pig rich? all the way rich according to my wideband. Even cutting the fuel pressure from 40 to 20. still rich. WTF? Obviously an electrical cause. This is getting old fast.. FI gremlins. Quote Link to comment Share on other sites More sharing options...
Gavin Posted June 7, 2007 Share Posted June 7, 2007 Did you wiggle the AFM plug over there on the left side perhaps? Or it's ground? Temp sensor connection? Quote Link to comment Share on other sites More sharing options...
ZR8ED Posted June 8, 2007 Author Share Posted June 8, 2007 It was electrical. I unhooked the SAFC started the car and it ran "ok" I then hooked it back up and everything was fine. I must have moved a wire while relocating the SAFC controller. I made sure all of the connections were tight again. Humphhh!?! Well .... back at it. Quote Link to comment Share on other sites More sharing options...
83 HKS L28ET Posted June 8, 2007 Share Posted June 8, 2007 s-afc wiring itself is gremlins. Quote Link to comment Share on other sites More sharing options...
