E88 head and FI?
flatbackz
ok. i pulled my head off and got a good look at my N47 head and intake today,and i dont think the FI intake will work with the E88 head even tho i was told it would. i might be wrong but as far as i can see the injectors will be spraying right into the side of the head as they have their own ports that run into the intake ports. the N47 head has a partial port on top of the intake ports as the E88 does not. im sure this is old news but maybe it will do someone some good.
it is not that difficult to modify the e88 to accept a injection manifold. You have to drill and tap a couple of holes to mount the manifold. There is plenty of material on the e88 to do this. I did this to my e88 a couple of years ago and it worked just fine.
It really is not that difficult. Just make sure you drill straight.
I used a injection manifold gasket (one that cleared the injectors) and used it as a template to cut 6 little notches in the head. It can be done with a round file.
