&$#&%*!! Gland Nuts
I've finally gotten around to pulling the entire suspension off of my 240 and have started tearing-down the struts. I've re-read the posts about plenty of penetrating oil(soaked repeatedly with WD-40 over 24 hours) and use of a torch flamedevil.gif to help persuade those pesky gland nuts loose... and the ^#@$! things will not budge! :mad:
I've only got one pipe wrench and have been clamping the tubes in a vise (hoping not to damage them not too severly) and wrenching on them. All to no avail. Tomorrow I'm gonna purchase a second pipe wrence and get them working in opposing directions like johnc or scca suggested. Keeping my fingers crossed. Any other ideas?
i tried to take mine off with a pipe wrench and damn near tossed them out my garage in frustration.
THEN!
i took them to minieke...where for 5$ a peice...i got to watch one of there guys try and try to get them off tongue.gif
they did get them off in about thirtie minutes...using two of thier biggest guys.
all in all im very glad i did...when i got them home i cleaned all the threds with a wires brush and then thourghly soaked them in anti-seize...cause i know im gonna have to do it again some day.
Here's what I did for one of my front struts (removed from car):
4' steel pipe on the stub axle
channel-locks on the gland nut
2' steel pipe on channel lock handle
5' steel rod inserted in 2' steel pipe
Then I put my foot on the pipe on the stub axle, and with my body fully stretched out pulled on
the ~6' compound extension on the channel locks. Musta looked pretty hilarious, but it worked! On about the 4th try. Not the best method, thougt I'd include it for yuks.
Oh yeah, on the car gland nuts have been known to back off on their own, no effort at all required.
Man, I'm glad my came off ok when I did the fronts, mine WOULD have ended up getting thrown out of the garage into the street or further depending on how long I'd been work on it. I had enough trouble getting the tie rod separated ,doesn't sound like a issue, but a pickle fork wasn't doing it and a puller type didn't want to work because the head of the tie rod was smaller than the american ones the tool was designed for. I think I invented some new cuss words that day... :D
Regards,
Lone
These days I have to keep my garage door closed while I work on my car for liability reasons :D
I have been known to throw things out the door when seriously frustrated. Several years ago I got pissed off while working underneath my wife's car and tossed a ratchet out from under the car, down the driveway and accross the sidewalk, narrowly missing the ankles of a neighbor out for a walk. Fortunately, I missed her and she had a sense of humor. :eek:
Ouch!!! :eek: ...and the smell of burning flesh fills the garage.
Seriously, I didn't heat them up that much. They smoked but weren't turning red. I'll try that if one of these other methods don't work.
If all fails with the torch and as a last resort, you can weld a long piece of steel to the Gland nut for a secure leverage..I never had to go this far since the torch usually does it
Wagz:
Yes, get the 2nd pipe wrench and then you can just lay the strut on the ground and hook up the pipe wrenches so one is flat on the ground cradling the strut tube as close as you can grab it to the gland nut (no point twisting your strut tube). Place the 2nd pipe wrench on the gland nut and have the handle 8-12" above the ground and the other pipe wrench handle and you can brace one foot on the strut tube and the 2nd on the raised pipe wrench so you're pushing the upper handle down towards the lower pipe wrench. If need be you can do your volleball jump training or practise your shumka training :D The dual pipe wrench has always worked for me. Clean the threads as best you can after and use loctite on reassembly as I've had a couple very highly torqued gland nuts come loose after time which is VERY annoying....
I didn't have time to get by Home Depot tonight and pick up a second pipe wrench, but I did find a 3ft. length of square, mild steel tubing hiding in the shop. It fit nicely over the handle of my wrench. So, I clamped the housings in my vise,heated those suckers up really good and was able to coax them loose with more leverage. Why couldn't I find that tubing yesterday?! :mad:
I'm waiting for the strut pin removal tool I odered from Dan Batha and I'll get the rear struts taken down. I should be ready to section them this weekend.
Ahhh, leverage, is such a wonderful invention.. :D Cool deal, suspension works sucks so much, nothing usually ever just comes loose. :rolleyes: Those highway guys need to do a better job of keeping the road clean, it really screws up our cars... :D
Regards,
Lone
