Help!!
Guest Bulldog55
Guest Bulldog55
Kinda new development. I took my 77 2+2 on a road trip last night. :) Took me back and forth 150+ miles no problems.:icon6: Started fine this morning took me to work. But, now at lunch time appeers I have a definate short.:fmad: I can watch the volt meter appeers normal upper end of the guage until I turn it to the run position. Then it drops to about 8 volts or so. If I then turn the key back off or into the acc position it takes 5-10 sec then returns to normal. (thinking this might be a relay?) It was very foggy and misty this morning could water been trapped someware that would cause this? :-( (I suppect but not shure wich lines to look at. I did the fusable link upgrade from Blue's pages and have had no issues prior. I've check the obvious batt cables fusable links ect...
Thanks!!
