Chewievette Posted June 29, 2007 Share Posted June 29, 2007 What kind of supporting mods would you need to do for a LD28T? Beyond say a normal L28ET swap. The Fuel system would have to be changed out of course but is there anything else that needs attention? and what exactly would you need for the fuel system? Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted June 29, 2007 Author Share Posted June 29, 2007 I am guessing the head would have to me modified for modern injectors. Also get a cummins or similar truck high pressure fuel pump (or whatever is used in a diesel)... Then go up in bore as big as you can go. With forged pistons you could raise compression ratio a bit from 20:1 to like 23-25:1. I'll start a new thread about building a LDT motor. With an intercooler, propane injection, and some other tricks you could have a fearsome little beast of a motor. Oil pickup would also have to be changed for a rear sump. Quote Link to comment Share on other sites More sharing options...
Chewievette Posted June 29, 2007 Share Posted June 29, 2007 And if that one turbo isnt enough you could alway compound it, simple enough on a diesel. 50psi easy. I hope you got good head studs! I'll have to look into this, it sounds very interesting and I happen to know where to pickup an LD for cheap. Quote Link to comment Share on other sites More sharing options...
