himself Posted July 1, 2007 Share Posted July 1, 2007 I cannot start MegaTune, when I click the icon I get this error message: Controller code version does not match signature in egaSquirt-I.ini. Expected "0x14" (found in ini file) Received "" (from controller) Table corruption may occur, this is usually a very serious problem. Terminate MegaTune now? Yes/No I have the cable plugged into my DB9 port and the Megasquirt, I tried the USB converter but my laptop did not recognise the converter and would not talk to it but the DB9 worked. How do I fix this? Quote Link to comment Share on other sites More sharing options...
himself Posted July 1, 2007 Author Share Posted July 1, 2007 One guy said to just hit "No" and ignore the error so unless anyone has a fix to the problem I'll just do that. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted July 2, 2007 Share Posted July 2, 2007 One guy said to just hit "No" and ignore the error so unless anyone has a fix to the problem I'll just do that. No, don't ignore this. Your Megasquirt is loaded with MSnS-E firmware, version 029v. The copy of MegaTune is currently set up to work with standard Megasquirt-I firmware. You need to configure it for MSnS-E and your code version before the two will talk. Trying to load settings will probably give you corrupted firmware. Quote Link to comment Share on other sites More sharing options...
himself Posted July 2, 2007 Author Share Posted July 2, 2007 Ahh, would that also be causing it to perform this error as well? Once I hit no and load up MT, run the diagnostic to make sure the port works and I can see the gauges move when I depress the pedal if I try and burn any setttings to the MS all the gauges turn pink and it says "no response." I know not to try and burn it with the car started but the key is set to on and it does this. Is this just a user error or related to hitting the no button to load it? Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted July 3, 2007 Share Posted July 3, 2007 The error message indicates that the MegaTune is set to communicate with a different firmware setup. Some of the communication (gauges, etc) still work, but trying to save any settings will get you in serious trouble. Fixing this mismatch should get everything else working, if you haven't corrupted the firmware. When MegaTune warns you're likely to get a serious problem, it's not kidding. Quote Link to comment Share on other sites More sharing options...
