GrayZee Posted July 4, 2007 Share Posted July 4, 2007 I am wondering how the vct works in a z32. What controls when and under what conditions it turns on. Basically we have a AEM computer and were thinking of modifying the how it is controlled, is this possible? Quote Link to comment Share on other sites More sharing options...
mtcookson Posted July 4, 2007 Share Posted July 4, 2007 I believe its simply an on/off switch. There's an actuator that pushes a "button" on the VTC assembly which allows oil pressure to build up and causes the timing change. Once off, oil flows through and timing changes back. Very simple. Quote Link to comment Share on other sites More sharing options...
Ferd/289 Posted July 9, 2007 Share Posted July 9, 2007 Here is an excellent url for Z32's// none better... but better use 'search' http://www.twinturbo.net/ Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted July 9, 2007 Administrators Share Posted July 9, 2007 Ferd/289 said: Here is an excellent url for Z32's// none better... but better use 'search' http://www.twinturbo.net/ Good source of Z-32 info there no doubt, yet they have more than a few yahoos that are pretty closed minded and not afraid to let you know that. Quote Link to comment Share on other sites More sharing options...
Challenger Posted July 9, 2007 Share Posted July 9, 2007 I dont know if you want to know actually how the VVT mechanisim works, but if you do go get the latest C&D and they have a write up on all the different ways VVT works. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted July 9, 2007 Administrators Share Posted July 9, 2007 Electrical diagrams for the factory service manual.. ECCS overall schematic; http://www.300zx-twinturbo.com/cgi-bin/manual.cgi?list=efec&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=13&design=default&total=190 VTC tech info; http://www.300zx-twinturbo.com/cgi-bin/manual.cgi?list=efec&dir=&config=&refresh=&slide=29&cycle=off&scale=0&design=default&total=190 When it is activated and not activated; http://www.300zx-twinturbo.com/cgi-bin/manual.cgi?list=efec&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=30&design=default&total=190 Wiring diagram for the VTC circuits, relays etc; http://www.300zx-twinturbo.com/cgi-bin/manual.cgi?list=efec&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=164&design=default&total=190 HybridZ member “booztd3” is also a great source of technical info… Quote Link to comment Share on other sites More sharing options...
Guest Chrispy Posted October 23, 2007 Share Posted October 23, 2007 If tt.net aren't being helpful have a look at www.aus300zx.com. Much better group of people Quote Link to comment Share on other sites More sharing options...
Sirk.240 Posted October 23, 2007 Share Posted October 23, 2007 I was looking at this today on a z32 we are finishing up at the shop. It's almost the same concept as V-tec. Except the cams run with it engaged using control oil pressure until like 5200 rpm to 6100 rpm? I may be off a few rpms but thats close. They must of come up with this to get rid of a dead spot during testing, I don't understand why they wouldn't grind them the opposite and have them kick on for a 1000 rpms instead of off... And I don't know why they wouldn't use the same concept on the exhaust cams instead of the intake cams so they could get some more exhaust flow at lower end. That'd probably be more beneficial. Quote Link to comment Share on other sites More sharing options...
Guest Chrispy Posted October 23, 2007 Share Posted October 23, 2007 I wouldn't really compare it to VTEC as that uses a different cam profile for the high rev range. I didn't think that it turned off until the revs reached 5200 again? I believe that they adjusted the intake to improve low end torque. Either way you woul achieve a little more overlap. Having the VVT on the exhaust could have stuffed up the crank angle sensor too. I'm sure nissan had a reason for doing it, just like AIV's Quote Link to comment Share on other sites More sharing options...
