Need MS-II up quick...
naviathan
Ok, I'm taking a week off work to do my head gasket and install MS on my DD. Since I already have a new cam and header I'm going to put those in while I'm at it. Matt and HizAndHerz are already working the VR dist issue. Once I'm wired in, which I'm sure I can handle easily enough, I want to make sure I have an .msq to jump off with and run. I've been playing with one at work with no ECU connected, but I think I might have it. Can someone look this over and tell me if I'm in the ball park or if I'm WAAAYYYY out? I'll be using stock injectors, GM IAC, GM Temp and IAT. Help me out.
EDIT: Nevermind....
Ok after plugging everything in, I can see that starting an msq without MS connected doesn't work. I'm still working with it as much as possible. Here's what I've got:
MSA Stage 2 cam (btw does anyone know what the cold specs are, I seem to have misplaced my cam card)
Pacesetter 3-into-2 header
GM coolant and IAT sensors
GM IAC stepper motor
locked NA VR dizzy (as soon as I get the locking part straight)
Everything else is a stock 81ZX N/A Can I get some suggestions for what I need to use as far as constants and enrichments and such. I think I have it figured out, but I'm not real sure. 14.8 is stoich right? I've read some people didn't get it to idle right without going down to 13.8 or so.
Just bought the Clewett Engineering Bosch to GM IAC Adapter Body. This thing looks promising. They designed it for the Porsche which uses the same type of AAR that we do. Here's a pic of it:
It's $96 which isn't bad when you consider what some of the IAC bodies are going for.
Wow, the EFI harness is extremely easy to pull out. It took all of 15 minutes to completely remove the harness and have it on the ground. One question though, my 81 looks like it had dropping resistors in place. Will I need these when I put MS in?
I have both the flyback circuits and the high current driver in my board. Although the high current driver I thought was for ignition, not fuel. In the tuning manual it says for low impedance injectors just to change the PWM % from 75 to 30. Seems pretty cut and dry to me.
Well, after a few bumps in the road the engine is back together. I'll have lots of pics to come. Still not real sure on my MSQ but the wiring is coming along nicely. I have to make a quick trip to the junk yard tomorrow for an IAC, but I have everything else I need I think. Funny I noticed on the injector connectors from DIY the red wire is actually on the ground side of the injector. Has anyone else noticed this? Anyhow, not a big deal, just glad I was looking for which side was hot. I have my MSA stage II cam in, PaceSetter header, which BTW, they chose a screwed up place to put the O2 bung. I don't have rack and pinion and the O2 hits the steering box. No biggie, it barely squeezed in there. I'll know tomorrow how things are going to run.
  naviathan said:
WFunny I noticed on the injector connectors from DIY the red wire is actually on the ground side of the injector. Has anyone else noticed this? Anyhow, not a big deal, just glad I was looking for which side was hot.
Actually, most injectors don't have any polarity at all and will work either way.
