naviathan Posted July 15, 2007 Share Posted July 15, 2007 I have several fuel injectors in my garage from several different Z's. Most of them are black bodies while I have a few green and one or two tan. Now I can't find the thread but I remember someone referencing black as a turbo injector. Which would make sense, I have a turbo car in the yard that has all black injectors. I can't find any flow info on them so can someone please put my mind at ease and tell me whether these are or are not turbo injectors so I know what to set my injector characteristics at for MS. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted July 15, 2007 Share Posted July 15, 2007 Most black injectors I have ran across are aftermarket. The stock ones for NAs are green and tan, while the turbo ones are maroon. The black ones I keep hearing about were bought from either Autozone or Sherco (sp?) automotive. Mario Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted July 15, 2007 Share Posted July 15, 2007 This may help...http://www.atlanticz.ca/zclub/techtips/injectors/index.html LARRY Quote Link to comment Share on other sites More sharing options...
naviathan Posted July 15, 2007 Author Share Posted July 15, 2007 Ok, well I have a part number on these injectors, but it doesn't match any of the ones in the list from the site cozy posted. Guess I'll have to do some more research to find out what the specs on these are. Thanks guys. Keep it coming if anyone else knows anything. Quote Link to comment Share on other sites More sharing options...
naviathan Posted July 15, 2007 Author Share Posted July 15, 2007 Got this clip from the zcar.com archives: After a day of searching 70-83 tech, I found others have had a simular problems getting GP Sorensen injectors from Advance or Autozone. I did find postings of casting numbers : N/A - D1560BA , TURBO- D1710BA These are numbers found in archives, I will see if they match up when injectors arive.. Got injectors today 5/14/06 and the casting #for the GP Sorensen N/A injectors all matched - D1560BA .. Advanced Auto was very professional getting the correct part......Randy Guess that helps. Mine are the D1560BA so I guess they're N/A injectors, but I haven't been able to find any true flow test or anytihng on them. Quote Link to comment Share on other sites More sharing options...
naviathan Posted July 15, 2007 Author Share Posted July 15, 2007 They all check out at 3.0 Ohm on the dot. Guess I'll go with these. Might want to check the turbo car and make sure they have the right part number on their injectors. Could be why the guy that had it before never got it to run right. Quote Link to comment Share on other sites More sharing options...
Daeron Posted July 16, 2007 Share Posted July 16, 2007 http://www.cosworthvega.com/Articles/InjectorTester/Homemade%20Injector%20Cleaner.htm might help, its a great idea at least. Instructions on how to build a rack to clean and test injectors. Quote Link to comment Share on other sites More sharing options...
naviathan Posted July 16, 2007 Author Share Posted July 16, 2007 I've seen that before, but wouldn't you burn up your injectors by putting a full 12V through them and holding them open? Quote Link to comment Share on other sites More sharing options...
Daeron Posted July 17, 2007 Share Posted July 17, 2007 well, yes you will.. apparently the cosworth injectors are not the same as ours, but still, all you need is a dropping resistor in line with your "trigger switch" to drop the voltage down to the appropriate point... OR, just get a small 5Vdc power supply to integrate into the thing. I haven't ironed out the details for a Z EFI version of the same thing yet, but I will one of these days.. I have about 70 injectors to collect, clean, test, and label so I can match an even set (or two sets??? Or maybe eight injectors total? who knows?? mwahahahaa) for my car. Quote Link to comment Share on other sites More sharing options...
naviathan Posted July 17, 2007 Author Share Posted July 17, 2007 That's what I thought. I have a cople dropping resistors so that's not a problem. Thanks for the ideas. Quote Link to comment Share on other sites More sharing options...
Daeron Posted July 17, 2007 Share Posted July 17, 2007 someone gave them to me I am just reciprocating. Quote Link to comment Share on other sites More sharing options...
