Guest wayne0 Posted July 18, 2007 Share Posted July 18, 2007 Hi All would really appreciate it if someone who knows their stuff could help me out, I have just had new cam bearings installed in my 305 s/b, the cam is brand new and straight, yet the cam doesn't turn freely, how tight should it be, is their a torque setting it should turn at, the bearings are the correct size and where placed in the right order. could the block alignment be out. block has been sitting on an engine stand for some time would like to know befor i complete the rest of the build. cheers Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted July 18, 2007 Share Posted July 18, 2007 Did you use oil, assembly lube, or cam lube (if included?) when you put it in? OTM Quote Link to comment Share on other sites More sharing options...
jt1 Posted July 18, 2007 Share Posted July 18, 2007 With a timing gear bolted to the cam, and no lifters in the engine, you should be able to turn the cam easily with your hand, not even close to having to put a wrench on it. Check all the cam bearings for any burs or lips. Sometimes there is a small lip from installing the bearings. If so, take it back to whoever put in the cam bearings. jt Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted July 18, 2007 Share Posted July 18, 2007 All the above is correct. Cam should spin freely to the point it wants to basical slip out. Who installed your cam bearings? I had a machine shop ( I do not use anymore ) installed some for me. I assembled the bottom end of the engine. Went to install the cam no go, tried everything. Finally took bottom end back apart, took back to the machine shop to check out with cam in hand. Come to find out they had a new guy and he installed the wrong cam bearings. From now on I always test fit the camshaft before doing anything else to the motor. Hope this helps, cam should spin freely, use plenty of assembly lube. John Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted July 18, 2007 Share Posted July 18, 2007 ditto, somethings wrong, it should spin freely with no lifters with minor finger applied torque only to the cam gear, stop, check, identify, verify and fix the problem before proceding further. you might want to coat the cam with assembly lube and roll it on a glass window or table to verify the cam itself is not bent, as thats a potential problem area, just because its a new cam does NOT mean its a strait core. Quote Link to comment Share on other sites More sharing options...
