dapiper Posted July 20, 2007 Share Posted July 20, 2007 Bosch lit says 14mmX1.5 but just received pump and closer to 1/4"NPT. Anyone know what size to get? And I thought the Germans were perfect. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted July 20, 2007 Share Posted July 20, 2007 Excuse me, have you tried 14mmx1.5? Quote Link to comment Share on other sites More sharing options...
dapiper Posted July 21, 2007 Author Share Posted July 21, 2007 14mmX1.5 it is. Bosch provided conflicting info as did almost everyone I talked to. Still think their motorsports div supplies 18mmX1.5. Installed 044 but need to qualify flow vs press yet. Inlet fed with -8 AN. Outlet 10mm hardline to Aeroquip which is sticking. Either 40 or 45 psi depending on phase of moon, temp or which direction you stand. Quote Link to comment Share on other sites More sharing options...
510six Posted July 21, 2007 Share Posted July 21, 2007 http://www.more-japan.com/Bosch-Fuel-Pump-Accessories-p-1-c-542.html Shot at 2007-07-20 I purchaced my adaptors from this source. Quote Link to comment Share on other sites More sharing options...
dapiper Posted August 2, 2007 Author Share Posted August 2, 2007 FYI get the Bosch motorsports 044 pump with 18mm inlet. I got from rx7store. Performance was 71-67 GPH at 40-65 psig with 13.7V @ 13-16 amp at pump. Use #12 AWG wire min. No need for #10 since most drop at fuse and relay. The 044 with 14mm inlet will only flow 45 GPH at 65 psig. This is the so called replacement pump available on ebay from the fuel pump king. Buyer beware. Bosch needs to have different P/N's. Quote Link to comment Share on other sites More sharing options...
