Will not idle
naviathan
I'm so fed up at the moment it's not even funny. The car will not idle on it's own at all. I've been playing with timing settings all day and still get get it to start without giving it some throttle and feather it to keep it going. I'm at a loss. I don't know what to do.
Let me elaborate a bit. This morning I set it to TDC made sure my rotor was pointing towards the number one plug and the crank pulley was at 0* as it was suppose, pulled a Timing Advance table off the forums recalculated my required fuel and started cranking. I stopped only to charge the battery when it got low and change the Trigger Offset value. I have been everywhere from -10 to 92 and still no start anywhere. What am I doing wrong here???
  • Replies 51
  • Created
  • Last Reply
Top Posters In This Topic
Do you have a timing light? before you even get it fired, you should make the timing light on the crank pulley match the MS-II readout during cranking. If you don't do that first, you are juggling too many variables at once and it will be like planning on hitting the lotto.
1)Confirm Timing. with a light and the trigger offset. (while cranking) disconnect the injectors or fuel pump.
2) Set the ignition MAP to 15BTDC all the way across (tweak later)
3) Set your injection to two squirts alternating or simultaneous
4) Enter an estimated VE for the idle areas of the map... 30 to 50 range my guess.
5) Turn off ALL or your enrichments AE,ASE, Warmup wizard.......
6) Go to the Required Fuel window and crank the key while going up and down with the Required Fuel number until it idles.
Did you adjust the idle screw on the throttle body? Adjust it so that it idles. Then check your timing with a light. it should idle fine at 25deg. The timing in the table for the active bin should match the light. Use the trim in the spark settings to compensate for any error. Once you get the timing and fuel right at idle, you may need to readjust the idle screw.
The maps look fine to start with. During cranking, watch the timing light AND the Trigger Offset window at the same time. Adjust the trigger offset number until they are as close as you can tell. My trigger offset ended up being (negative) -66.
You mean the Trigger Wizard under tools right? The one that says match timing light to the above value? My timing light is static and all I can go by is the timing plate by the crank pulley.
  naviathan said:
Adjust the idle screw? I have a GM IAC stepper motor. The only thing that I can adjust on the throttle body is the TPS and the throttle plate stop screw. Is that what you're talking about? The stop screw?
Yes, idle stop, idle screw, whatever you want to call it. It is how you adjust how much air goes into the engine at idle.
Are you sure it is the VB921? You have the spark inverted in your settings (as it should be). The VB921 should be driving the negative terminal of the coil.
Does that screw really need to be adjusted? I thought the IAC would take care of the idle air flow.
Oh yes the VB921 is blown, bad. It melted the nylon screw to nothing. I plugged it into the stim and I'm getting everything except ignition.
On further investigation I think it was either the jump box I had connected to the battery to keep everything going or the pull up resistor that blew the driver. One of the legs on the pull up appears to have broken contact. I think it was intermittently making contact and might be what did it. This time I'll do my pull up on the board and not in the wiring like I had it.
  Quote
Any given engine will require an airflow to idle, you can start by opening your idle valve all the way. If that is not enough air, then you need to open the throttle plate to allow more air. As simple as that.
Every engine I start with megasquirt I do two basic things. I have someone else crank the engine from inside the car while I check the cranking timing with a light (without checking timing how will it ever start, just by luck?), and then I operate the throttle blade by hand while they crank it over. That way I can adjust the airflow to get it to start, then adjust the idle screw to hold the plate open. This method works very well, all engines start right away with the required fuel calculated from megasquirt.
