Standalone?
jkgts1
Hi, I am planning to do a sr20det swap in my 260z. If I go standalone ecu will I need all the cam angle sensor, ignitor chip, or maf? I am just trying to figure out what I need, so I don't spend more $$ than I have to.
Thanks
  • Administrators
It depends on which EMS you choose.
The Nissan CAS is a pretty good system, when used correctly... but not all EMS systems are compatible.
By "ignitor chip" I assume you mean ignition ignitor. Some EMS's will have them built in, but most of the high-end systems will not, to allow the use of the OE ignitor, 'x' brand, or CD ignition.
The MAF can 'disappear' on virtually all of the aftermarket EMS's.
