Guest zDriftKing619 Posted July 27, 2007 Share Posted July 27, 2007 I installed new wires, plugs and a few hoses but the car still wont start. It cranks and turns over but wont idle. Maybe its not getting enough fuel. I noticed that the intake manifold looks like it needs a new gasket and the distributer is loose so the timing is off. Where should I start? I'm really close to giving up and parting the car out to make room for an engine swap.... Suggestions??? Quote Link to comment Share on other sites More sharing options...
gjc5500 Posted July 27, 2007 Share Posted July 27, 2007 1. check for spark 2. check for fuel pull a plug and crank it w/o the coil having power. if u smell gas, you have fuel. Quote Link to comment Share on other sites More sharing options...
JSM Posted August 1, 2007 Share Posted August 1, 2007 Did it run better b4 you did this work? Did you happen to cross spark plug wires? You need to really get the distributor tightened down and set. That will definitely affect your idle if it is off. Quote Link to comment Share on other sites More sharing options...
Guest zDriftKing619 Posted August 2, 2007 Share Posted August 2, 2007 Should I tighten the distributer down at top dead center? I bought the car not running and just started replacing items. I was also told the car wont start with a bad altenator. Is this true? Quote Link to comment Share on other sites More sharing options...
JSM Posted August 2, 2007 Share Posted August 2, 2007 Check out this about timing: http://www.zcar.com/forums/read/1/349436/349436#msg-349436 I'm not 100% about the bad alternator but if your getting spark and fuel the bad alt should only impact the charge of the batt. As long as your batt is 100% charge you should be okay for a little bit. Quote Link to comment Share on other sites More sharing options...
