280z with 83 280zxt engine and wiring only 1 spark per rev on dist!!!
hi i wired everything up according to all the writeups on sticky in the forum. when i crank engine over it only spark 1 time every second or so when it should be sprak spark spark spark as the rotor turns to send spark to each wire. anyone know what might be causing this ? please let me know im desperate. thanks.
i should also add i hav hooked up the blue and red fuel pump signal wire because i cant find it on the 280z. does anyone know where this is ? please let me know and then i think the cas with work and i will get spark when ecu can sense the fuel pump ciruit in the ecu is getting used.
