Modify a 350 '79, or wait and buy an LT1?
Hi guys, let me introduce myself... (first, sorry about my english....)
I'm from Guatemala, i have a 280Z '75, and i want to do a
swap to a 350 chevy...
I have a '79 350 from a K5 Blazer, do you think do better modify
this 350 or wait and get the money to buy an LT1?
If i decide to modify the engine that i have, i can take my time
and expand my budget a little bit.. so i expect you can help me
to think about the things that i could put in that 350...
Thanks a lot guys...
I guess it all depends on what you want to do. The LT1 definitely has some advantages such as reverse flow cooling, fuel injection, and aluminum heads (depending on what vehicle the engine comes from).
If you're planning fuel injection, I'd say it would probably be better to wait for an LT1 engine. They are failry readily available and relatively inexpensive as well (not sure on availability and cost where you are).
The aftermarket support is still good and there is plenty of information available online. There will be additional difficulty on the install with the wiring, but I think it would be well worth it in the long run. You can also purchase applications that will allow you to monitor and diagnose your engine as well as modfiying parameters the PCM is using. Of course you would need a cable and a laptop for this.
Thanx for your input... in the case that i decide to rebuild my actual 350,
i would stay with a carb...
I was thinking on buying a Federal Mogul Rebuild Kit from summit, what do
you think about that?
And in the case that i decide to wait from a LT1 i was planning to take one
from a wrecked camaro or firebird... that would be ok i think...
Thanx for your inputs...
