Guest BadKarmaCreepin Posted September 12, 2002 Share Posted September 12, 2002 i've seen a bunch of cars do this (5-speed) where they're sitting still and just roast the back tires with the front's stuck in place. is that just the e-brake? or is there something else going on? like this little POS z3 did it while i was sitting waiting for my bus, and i was like, "i don't get it" thanks. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted September 12, 2002 Share Posted September 12, 2002 Usually just holding the brake pedal and side stepping the agas pedal is enough to do it. The rear brakes don't hold as tight as the fronts. Otherwise installing a line lock on the front brakes will work better. Tim Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted September 12, 2002 Share Posted September 12, 2002 It's kinda like using both feet to control the go pedal, the brake, and the clutch. Simply put the heel of your right foot on the brake and the toe of your right foot on the go pedal, then use the left foot to control the clutch. Takes a while to get it right without frying your clutch or stalling out. !M! Quote Link to comment Share on other sites More sharing options...
Tim240z Posted September 12, 2002 Share Posted September 12, 2002 Hmmm, Matt, I've never tried it that way...I've always put my 'toes' on the brake pedal and used my heel on the accelerator....maybe your way is easier...I'll have to try it (when the V8 Z is done, the L24 will just poop in it's pants if I try it) Tim Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted September 13, 2002 Share Posted September 13, 2002 Originally posted by Tim240Z:.., the L24 will just poop in it's pants if I try it.., Tim I hate it when that happens; poop in the pants that is! Thank goodness for Depends. Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
jaime240z Posted September 13, 2002 Share Posted September 13, 2002 Yeah, and if you've got a clutch DON"T pull up on the e-brake while trying to smoke the tires. That only works for front wheel drive. Quote Link to comment Share on other sites More sharing options...
