Toyota S13W calipers dimensions
hey guys, found that a Jaguar XJS caliper fits into this strut.
it has an extra 26mm of rotor spacing took my setup from 270mm to 296mm and has a 27.27mm rotor gap, if any one is interested I can get some pics and sizes posted?
Yes please
Kirby.nankivell_a_gmail.com
Yes pics and is this caliper a 4 pot like the S12W and S13W?
Caliper Specifications:
Hilux S12W A:28.9mm B:88.9mm 3.5inch C:23.3mm D:103mm E:63mm 4 Piston @ 43.5mm
Hilux S13W A:31.5mm B:88.9mm 3.5inch C:29mm D:112.5mm E:??? 4 Piston @ 45.3mm
Jag XJS A:32.5mm B:88.9mm 3.5inch C:27.3mm D:106mm E:77.25 4 Piston @ 43.5mm
Sorry for the late relay I had problems getting images loaded, if you need any more let me know,
Also if some one can confirm the E: mesurment for the S13W please I estimate it at 65mm but I want to be sure?
If any one is interested I maybe selling these as I can get a rotor to fit under these yet, but still looking
NOTE: This is a Toyota setup.
Interesting. You said you can fit 298mm discs with this setup?
What year Jag are the calipers? I'd be interested in purchasing them for sure.
Hi, they will fit a 296mm rotor on my setup, you will need to see what size rotor the S12W will take on your setup then add the difference in size. if you take the S12W at E:63mm and Jag E:77.24 = Radial differance of 14.24mm this would add another 28.5mm diameter to your setup, reading posts (Hybridz) the S12W is used with the 300ZX rotor which is 274mm making this caliper fit a 302mm rotor which sounds wrong?
NOTE: On a toyota the S12W take a 268mm rotor & S13W reported to take 276mm
I got this from a Cobra setup so I dont know which year model Jag they are from only that is the XJS model.
If anyone has the Height E: for the S13W that would be helpfull.
PM me if you want to buy these.
  • 3 weeks later...
  • 8 years later...
