AKWIKZ Posted September 14, 2007 Author Share Posted September 14, 2007 I apologize for not responding earlier. I will be calling Courtesy shortly and will let you know. Thanks again. Brian Quote Link to comment Share on other sites More sharing options...
AKWIKZ Posted September 14, 2007 Author Share Posted September 14, 2007 Allright. I was able to get everything except for the eye bolt. Apparently the Z32 uses a banjo fitting instead of the adapter the GT-R uses. So, does anyone here have a spare set of turbos that might have one of these they can part with? It is a pretty simple looking thing. More or less a hard line adapter into the turbo. My next step might need to be Earls fittings or something. Anyone, anyone? Brian Quote Link to comment Share on other sites More sharing options...
Careless Posted September 15, 2007 Share Posted September 15, 2007 Allright. I was able to get everything except for the eye bolt. Apparently the Z32 uses a banjo fitting instead of the adapter the GT-R uses. So, does anyone here have a spare set of turbos that might have one of these they can part with? It is a pretty simple looking thing. More or less a hard line adapter into the turbo. My next step might need to be Earls fittings or something. Anyone, anyone? Brian Hi Brian, Glad all the parts number worked out =) Did you try both part numbers that I provided for the eye bolt? remember, I cross referenced it to the Z32 one that they had listed @ courtesy nissan. Have you tried the very first one I listed? If you want, I could call up my Parts guy tomorrow and see if he can get them. But it takes a little while for the parts to come in. say around 3 to 4 weeks. =( Regardless of whether you can wait that long, i'm going to see if he has access to them, and I'll post what I find here. check a fastener place, they should have some close alternatives. Raff Quote Link to comment Share on other sites More sharing options...
