important question. I broke something?
Omar
so i went to change my coolent temperature sensor on my l28et. at first i couldn't find it. then i saw this unti that looks kinda like it(at least the clip was the right fit). i proceeded to try to take it off and it snapped. it is not made to be removed b/c there is no threads. oops.
1. what is the piece called that i broke the sensor off of?
2. wtf does it do? (its got this spring loaded port with a sensor inside)
3. is it the same on an n/a l28e?
came from here
Hey bro. That's the Air Regulator. It bypasses the throttle valve, to control the quantity of air required for increasing the engine idling speed when staring the engine at an underhood temp. of below 80 degrees C. (176 degrees F.) Here are a few pics from my service manual for what you might be looking for.
The thermotime switch works in conjunction with the cold start valve, so that's not it, even though it has the same plug type. I think that the part you're looking for is the cylinder head temp sensor. (this also has the Bosch style plug). Here's another pic (where it is on the engine) from my manual.
I know it's blurry, but the sensor is located on the passenger side under the spark plugs and above where the dipstick is. Hope this helps.
that's very very helpful. now I just need to know if the n/a has the same on. b/c that can be had at the yard for almost nothing. (no turbo Z at the yard)
problem fixed. thanks man.
It should. The N/A and the turbo ZX's are pretty much the same when it comes to coolant stuff. Just check the thermostat housing and the back of the cylinder head to see if they're the same. Hope everything goes well!!!
