Guest bbritten Posted September 5, 2007 Share Posted September 5, 2007 I'm thinking about buying a 280z with the intent of doing an LS2 or LS6 swap. How difficult is the swap compared to other imports like the RX-7 and how much work and effort on custom parts will be required. Any help would be appreciated. Thxs Brett Quote Link to comment Share on other sites More sharing options...
m1noel Posted September 5, 2007 Share Posted September 5, 2007 Read LS1 sticky at the top of this forum. It will explain pretty much all of it as the LS1 and 2 are pretty much the same except for the wiring which is maybe just a little easier for the LS2. You might check out the link in my sig also, and check out Ulises car. Mike PS. the LS2 has electronic throttle by wire which works well if you get the pedal from a donor car and eliminates the throttle cable. Quote Link to comment Share on other sites More sharing options...
LS1 240Z Posted September 6, 2007 Share Posted September 6, 2007 the truck 6.0s dont produce as much hp in stock form but are much much less.. you can get one from 800-2500 complete. Quote Link to comment Share on other sites More sharing options...
