Guest okdan Posted September 10, 2007 Share Posted September 10, 2007 Does anyone know the diameter for the squirrel cage on the blower motor on a 76 280z also if you know what is the largest diameter that will fit (I just bought a motor that did not come with the fan -- the guy that sold it has a bunch of random fans in a box but no clue if any are the right size-- just need to know what size(s) will work?? Thanks Dan Quote Link to comment Share on other sites More sharing options...
deja Posted September 10, 2007 Share Posted September 10, 2007 A '94 Camaro fan and motor will fit inside the Datsun housing with a little tweaking of the mounting screw hole and clearance for the Camaro wiring connector. Quote Link to comment Share on other sites More sharing options...
Guest okdan Posted September 10, 2007 Share Posted September 10, 2007 Deja do you know the diameter of the fan from the 94 camaro??? or if anyone knows diameter of what will fit -- Thanks Dan Quote Link to comment Share on other sites More sharing options...
deja Posted September 11, 2007 Share Posted September 11, 2007 Deja do you know the diameter of the fan from the 94 camaro??? or if anyone knows diameter of what will fit -- Thanks Dan Sorry, I didn't see this last night. I will check the diam of the Camaro fan tonight. But it will fit in the Datsun housing, motor and all with minimal modification to the housing. Quote Link to comment Share on other sites More sharing options...
deja Posted September 11, 2007 Share Posted September 11, 2007 Deja do you know the diameter of the fan from the 94 camaro??? or if anyone knows diameter of what will fit -- Thanks Dan The camaro fan is almost identical to the 280z fan. 5 3/8" in diam and 2 7/8 tall. But it has a lot more fins. Quote Link to comment Share on other sites More sharing options...
