After the RB25 Swap Help!!
zigen9
first thing get a muitl meter like a fluke or something that can read amps
second carefully connect the meter in series with the battery and the positive cable.
do not turn the car on.
you should get a little bit of a parasitic drain. its normally just a few miliamps
if its more than that ( which it sounds like it is). with the meter hooked up start pulling fuses. when you pull a fuse that makes the drain alot less ( smaller reading on the meter) thats the circuit the drain is on
this method is the easiest if you do not have alot of electrical experience. once you know what circuit it is this will tell ya what components are on it and narrow the possiblities of what is causing the drain:mrgreen:
