YellowFever Posted September 15, 2007 Share Posted September 15, 2007 I'm having a tachometer problem after swapping my '76 280z distributor (dual pickup electronic distributor) with an early 280zx NA distributor. I followed the instructions @ AtlanticZ http://www.atlanticz.ca/zclub/techtips/distributor/index.html The car starts and runs... but the tach only works while the key is in the start position. As soon as the key is released (to return to the run position) the tach quits. All of the other gauges continue to function normally. Any ideas what might be causing this problem? Quote Link to comment Share on other sites More sharing options...
YellowFever Posted September 15, 2007 Author Share Posted September 15, 2007 The plot thickens... I just went for a ride in the car. It runs great, and the tach kinda works. At idle the tach is dead but it springs to life once the RPMs have reached 2,000 or so. The tach will function normally as long as the RPMs remain high... as soon as the revs drop below 2,000 the tach quits working again. Weird, huh? Could this be caused by a bad ignition module on the brand new distributor that I installed? The entire distributor (including ignition module) was only $105 from AutoZone. Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted September 16, 2007 Share Posted September 16, 2007 i know on 240s you have to swap a 280z tach for it to work. i swapped an autometer tach in mine, but mine is intermittant under 2 as well..... Quote Link to comment Share on other sites More sharing options...
