Guest Pegasus76 Posted October 20, 2002 Share Posted October 20, 2002 Does the stock 1976 r200 differential come wiht limited slip? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 20, 2002 Share Posted October 20, 2002 nope.. go to the years: 1987-89 300 ZX Turbo Quote Link to comment Share on other sites More sharing options...
Guest jens Posted October 20, 2002 Share Posted October 20, 2002 Does this mean that the 280zxt rearend is open eventhough it has cv axles. Quote Link to comment Share on other sites More sharing options...
rags Posted October 20, 2002 Share Posted October 20, 2002 Yep, it's open. Joe Quote Link to comment Share on other sites More sharing options...
Guest jens Posted October 20, 2002 Share Posted October 20, 2002 Does this mean that to get a 3.54 diff rearend i have to mix parts between a 280 and a 300 zxt or is there a factory installed limited slip 3.54 r200 in other cars Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 20, 2002 Share Posted October 20, 2002 Yep and it really gets painfully expensive Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 23, 2002 Share Posted October 23, 2002 Take off the cover and rotate the large ring gear looking for numbers (3.54=39.11) (3.70=37.10)(3.90=39.10) (4.11=37.9) 3.54 1975-78....81-83 Turbo is 3.54 ....81-83 non turbo is 3.90 ... 8?to 86 200SX is 4.11 ....87-89 300zxt is 3.70 LSD...... 88 white has "viscous drive" on tag on diff.the seller probably has a 3.54 trbo diff with CV Quote Link to comment Share on other sites More sharing options...
Guest jens Posted October 23, 2002 Share Posted October 23, 2002 Is there any numbers that tells thats inside. The seller says its a 280zxt rearend. The cover is aluminium with fins in the lower part. The cv axles looks like it is a 280zxt. Quote Link to comment Share on other sites More sharing options...
Guest jens Posted October 23, 2002 Share Posted October 23, 2002 Have you heard of a 83zxt anniversiry edition sold in europe. He claims this model had lsd and some other options Quote Link to comment Share on other sites More sharing options...
fl327 Posted October 24, 2002 Share Posted October 24, 2002 only 87-89 are limited slip. none other came with limited slip, and ive never seen a 300zx that matches the description in the yard with its diff intact-always gone Quote Link to comment Share on other sites More sharing options...
