X64v Posted October 9, 2007 Share Posted October 9, 2007 As the title says. I need a red 20 tooth gear for the 4.11. I found this place, and the price is right on the gear, but $10 just for shipping? I'll do it if I have to, but first does anyone know of any other sources, or simply have that gear I could grab for a few bucks? Quote Link to comment Share on other sites More sharing options...
Kkittels Posted October 9, 2007 Share Posted October 9, 2007 Have you tried Courtesy Nissan Parts?http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=CP&Category_Code=s30_nismo_pinion Quote Link to comment Share on other sites More sharing options...
DHale_510 Posted October 9, 2007 Share Posted October 9, 2007 4 speed gears are longer than 5 speed gears, and there are two housings for each style depending on how many teeth are on the gear. Parts do not interchange between long and short or big and little offset housings. You may have more trouble than a $10 shipping charge ahead.... Quote Link to comment Share on other sites More sharing options...
X64v Posted October 9, 2007 Author Share Posted October 9, 2007 I have had no trouble swapping between 4 speed gears and 5 speed gears. I currently have a 4 speed gear in a 5 speed housing. I know there are early and late housings (one's black and one's gray), but are you saying there are two different black (early) housings, and two different gray (late) housings? Quote Link to comment Share on other sites More sharing options...
DHale_510 Posted October 10, 2007 Share Posted October 10, 2007 OK, you're right about the length. It is the sedan and Roadster 4 cylinder 4 speed that uses the longer gear and sleeve. The short sleeve does come in two lengths though. 16-19 tooth has less offset than the 20-23 tooth one. Likely the original poster is converting from 18 or 19 teeth to 20 teeth. Half credit each. Quote Link to comment Share on other sites More sharing options...
