need help with combo switch
so i cleaned my combo switch and got the turn signals all working. just to make sure they all work, i turned the left on (dash, front and rear work) then tried the right (everything again) then turned the headlights on, tried the left turn signl with headlight on (everything worked) kept the headlight on tried the right turn signal (stopped working, headlight, and rear turn signal working, just not the dash and front) anyone ever have this sympton?
please some suggestions. i now have cleaned the switch a few times, each time it gets all the turn signals to work, then after a few tests the right front and right dash turn lights dont work. i might not be cleaning it correctly. what i did was cleaned sodered wire areas with eraser, as well as wire connectors. then i cleaned the switch with electrical cleaner from radio shack. then like i said, it works then stops working. what else do i need to clean? also i changed the relay and i still have the same problem. please, any suggestions would be helpful.
thanks
