L26 with p90 head+turbo
Blobber
The l enigne calculator is good for standard parts, I used 2mm steel gasket which had larger bores, .5mm oversize New flat top pistons which had a slightly different deck height....it all added up to 8.35:1...the standard l28 with standard gasket and flat top pistons would have a CR of 8.52:1
Compression ratio is not where the problem is. Once you look at the parts dimension, the real problem becomes apparent.
L26 block + P90 head is a poor combo because the P90 chamber width(approx 86mm) is bigger than the L26 bore(83mm), that leads to a variety of problems.
will the valves hit the cylinder wall? that is a possibility if valve lift is high enough.
even if the valves clear the wall, you will have serious shrouding problem. Not to mention the step formed at the chamber wall-to-cylinder wall is bad for air flow and bad for uniform fuel distribution. You need a bore size that is as big or bigger than the P90 head chamber width(86mm).
Well, that's totally new thing to me. And obviously it makes sense, so then I have to forget p90 and n47. I'm surprised that you are the first one to tell me this. But now we are back to square one. Is there a EFI head with 83 bore? n42?
If I'm going to get a new engine, I'm going to ge L28ET as complete as possible. I had one seller, but I'm not sure what's going on with him. I asked from fourways engineering in uk and their prices were skyhigh comparing to getting the engine from states+delivery and taxes.
