jgkurz Posted October 16, 2007 Share Posted October 16, 2007 Ok, I know the title sounds strange but it's the most accurate description I could think of. Here's my problem. I bought a new Optima battery for my 1977 280Z and it's roughly 1.25" shorter than the OEM battery. I got a deal on the Optimal so I want to make it work. Basically I need to lift it up 1.25" so the battery hold down mounts to the firewall and fits properly over all. I priced 1.25" thick plexiglass and it's $50.00 for a 12x12 piece. Wow! I don't want to fabricate the battery hold down to accommodate the short battery and I don't want to use wood. Any idea where I could find a piece of 1.25" plastic or other material? Quote Link to comment Share on other sites More sharing options...
gokiburix Posted October 16, 2007 Share Posted October 16, 2007 the optima battery should have came with a plastic "lid" type thing. I put that on the bottom of the battery to use it like a "spacer". Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted October 16, 2007 Share Posted October 16, 2007 ebay has tons of optima spacers. check there and see if you find anything owrthwhile. i said screw it and mounted in the rear Quote Link to comment Share on other sites More sharing options...
jgkurz Posted October 16, 2007 Author Share Posted October 16, 2007 Excellent! The Optima spacer will work perfectly. Thanks for the quick response. Quote Link to comment Share on other sites More sharing options...
GeeZ Posted October 17, 2007 Share Posted October 17, 2007 I found that the Optima battery, with the center post made it difficult to place the cables in my early 260Z. The cables were apparently just long enough for the stock battery. I think these cables are oem. It just easier to use the stock config. battery. Quote Link to comment Share on other sites More sharing options...
gokiburix Posted October 17, 2007 Share Posted October 17, 2007 no problem...we're all here to help Quote Link to comment Share on other sites More sharing options...
