Blobber Posted October 25, 2007 Share Posted October 25, 2007 What would be the best and easiest option, when I'm swapping L28ET to my 260z and I'm doing the automatic to manual conversion? I have searched that BW T5 would the absolute best option, but it requires modifications to transmission mounts and to the driveshaft. Also I can't use the original driveshaft. How about if I use 280z's 5-speed transmission? Will it bolt to the L28ET engine and then can I use the driveshaft which I have now and stock transmission mounts? Are the 280z'z 5-speed and the 280zx na's 5 speeds trannies the same? Quote Link to comment Share on other sites More sharing options...
ktm Posted October 25, 2007 Share Posted October 25, 2007 Since I am feeling generous today, I'll hold on the search comment. How about if I use 280z's 5-speed transmission? Will it bolt to the L28ET engine and then can I use the driveshaft which I have now and stock transmission mounts? Yes. Are the 280z'z 5-speed and the 280zx na's 5 speeds trannies the same? No. The only significant difference in the gearing. Quote Link to comment Share on other sites More sharing options...
Blobber Posted October 27, 2007 Author Share Posted October 27, 2007 I searched, but as a foreigner it's harder to find right info because here is so much talking going on. Don't shoot or anything, but I have one question. Can I use the 280zx na's 5-speed with L28ET and my driveshaft L26+automatic combo? I know that BW T5 needs different driveshaft, but does the na's 5-speed need that? Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted October 27, 2007 Share Posted October 27, 2007 Most folks opinion is that the stock n/a 5 speed is a better tranny than the T5. That is what I swapped on my 81 and it worked fine. don't forget you need the clutch hydraulics. Make sure you get a driveshaft match that is what gave me the most problem. Quote Link to comment Share on other sites More sharing options...
