Guest ON3GO Posted November 21, 2002 Share Posted November 21, 2002 hey everybody i plan on running 16x10 rear and 16x8 front on a Wantebee rim. size tires are 265-45-ZR16, and 235-40-ZR16 front..... ill be using the ZG flares, and Ground Control coil overs or whatever comapany or person makes better, and tokico illumina shocks and struts. will that work? mike Quote Link to comment Share on other sites More sharing options...
Mudge Posted November 21, 2002 Share Posted November 21, 2002 I saw 245s on a 240Z in the front with no spacers or flares, but the car was not lowered or at least not much, it had 265s on the rear but had homemade flares due to laws in CA. Quote Link to comment Share on other sites More sharing options...
Guest racerxlite Posted November 22, 2002 Share Posted November 22, 2002 I have 17x9.5 inch rims w/ 275/40/17's on my 75 280 w/ the Ground Control coilovers on the car, no problems. The back space on the rims is 5 inches. I have a friend that has 15x10's on his w/ 5.5 inches of backspace. They fit great. You should have no problems w/ the rims you want. Quote Link to comment Share on other sites More sharing options...
Guest Z-rific Posted November 22, 2002 Share Posted November 22, 2002 I don't understand how 5" backspaced rims fit on a Z. How do they not hit the spring perch? The original Z wheels had what, 3.5" backspacing? And even then, there is only about an inch to play with. 5" backspacing puts the wheel 1.5" closer to the spring perch. It seems to me, and I could be WAY wrong, that any wheel with 4" or less backspacing should clear the spring perches front and back. And this should be first priority, as fenders can always be rolled or flared to clear larger wheels outward. Quote Link to comment Share on other sites More sharing options...
johnc Posted November 22, 2002 Share Posted November 22, 2002 With aftermarket coil-over springs and perches you're reducing the spring and perch diameter to 2.5". That picks up enough space to increase backspace to 5" with 8 or 10" long springs and to 5.5" if you crank the perch up and run shorty springs. Quote Link to comment Share on other sites More sharing options...
