My pulley situation
  • Administrators
Looks fine from that angle. How do they line up with each other? I.e. are all three pulleys grooves that your belt is riding in, are they all in that exact same plane with each other?
The other two grooves were used for other accessories from the GM factory and that second belt also ran on the crank and water pump at the same time as well as the accessory, which could’ve been P/S, A/C, smog pump, etc..
Searching for "water pump pulley spacer" on a popular mail order web site (climb that mountain's peak) produced a $6 kit:
Water Pump Spacer; Water Pump Pulley Shim Kit; Incl. 0.0625/ 0.125/ 0.1875 in. Shims; Chevrolet Water Pumps.
Shims one and three add up to .250, by my math...
Cheers -- Gary
