TurboSouthAfrican Posted November 3, 2007 Share Posted November 3, 2007 I have a RB26 with 25 tranny in it. My clutch went south but I do not know if the flywheel is from the 25 or the 26? I have heard of some guys running a RB25 clutch and flywheel with a RB25 starter on the 26 motor, or do I just have all the facts messed up here. Are they interchangeable? Is there a chart with size of the ring gears or spline counts somewhere? I need to order a clutch but I am hesitant to order the wrong thing, please help. Thanks Larry Quote Link to comment Share on other sites More sharing options...
TurboSouthAfrican Posted November 4, 2007 Author Share Posted November 4, 2007 Anybody, I am not too proud to beg you know!!! Just looking for information on the parts I have, or a site that has size's of stock parts or no's, thanks. Larry Quote Link to comment Share on other sites More sharing options...
Careless Posted November 4, 2007 Share Posted November 4, 2007 You can use an N/A Z32 clutch casing and friction plate on an RB25 and 26 flywheel, as it will bolt in, so my guess is that the same clutch casings that work on the 26 will work on the 25. But get a 25 one cause you have a 25 transmission. Atleast that's what I would do if you were in a serious crunch. or else, try and do some google searches, you'll find it on nico.com, freshalloy.com, or zilvia.net or something, im sure! Quote Link to comment Share on other sites More sharing options...
TurboSouthAfrican Posted November 4, 2007 Author Share Posted November 4, 2007 You can use an N/A Z32 clutch casing and friction plate on an RB25 and 26 flywheel, as it will bolt in, so my guess is that the same clutch casings that work on the 26 will work on the 25. But get a 25 one cause you have a 25 transmission. Atleast that's what I would do if you were in a serious crunch. or else, try and do some google searches, you'll find it on nico.com, freshalloy.com, or zilvia.net or something, im sure! Thanks for the help Quote Link to comment Share on other sites More sharing options...
