Wheel offset question
I've searched, but haven't had any luck with finding the answer to my question. I plan on putting tokico hp/illumina shocks with tokico springs on my 240z. I also plan on getting ZG flares, so my question is...what offset would I need to fit 16x7 front wheels and 16x8 rears? I want to be able to fill the flares pretty good without spacing much. Thanks in advance
0 offset would be perfect for stock fenders/guards but with ZG you will want a bit of negative offset to push the wheel out to fill the ZG overfenders. Most run 8.5" -6mm front and 9.5" -19mm with ZG flares in Japan so if you want 7" and 8" (having been there and since sold the rims as they did not fill the guards enough) you should be looking around the -20mm to -25mm offset which is a lot then then you start adding too much load on the bearings due to the track changes etc.
