tig/plasma combo machine
stony
Main reason i ask is I dont know jack about tig welding but i want to learn.... BUT i dont want to learn that the unit i buy ends up not having enough UMMMPPPFFFF to get the minor tasks like intercooler piping and smaller aluminum welding done.
So any imputs are welcome.
ive been welding up my intake manifold using a Miller TIG at school..
for thin aluminum I am using 70amps.. and about 60hz.. for thicker material and welding the thick flange to thin piping, I am using about 120hz.
Lower frequency is a bigger puddle... less penetration
Higher frequency is a narrow puddle with deep penetration.
Greater amperage is obviously more heat
you really shouldnt need anymore than 150amps and 200hz for everyday aluminum.
FYI - you can weld aluminum with a MIG... comes out fairly well too
K i spoke to my welding instructor..
he said its a good unit.. cant weld alot of thick stuff.. like 1/4" is about max with steel or aluminum.. he recommended multiple passes for 1/4" or anything thicker. Bevels rock.
For the money though.. you can probably find a used Miller on craigslist with low hours. Plus I dont know if this unit has a cooling unit to cool the tungsten.. those puppies can produce an arc 20 times hotter than the surface of the sun.
