289 frankenstein
TABrinn
My brother has a 351W block he is willing to give me for free.:) A friend of mine has a 289 crank for an excellent price. This combo gives a 289 with a killer rod ratio. From what I understand should outperform a similarly equipped "regular" 289. Before I get flamed for not going stroker, read up at www.victorylibrary.com/mopar/rod-tech-c.htm. The main journals are different. 351W has 3.00" and the 289 has 2.25". Can a spacer such as Ford Racing PN: M-6339-A351 be fabricated to fill the gap? Would something this large (.75") be advisable? Anyone know a good machine shop that would be willing to do this?
The 289 already has a pretty nice RL/S ratio as is. The heavier weight of the Windsor block, larger external dimensions (I'm swapping my 289 out for a 383 Windsor), and heavier rods may negate any expected gains from the even larger ratio. I can appreciate a nice ratio being I opted for the 383 instead of the 427 stroked Windsors, but my guess is that you'd be happy with the 289 as is, and it will be a lot simpler to find good components. I twist mine to 7500 almost every time I crank it up, and this is with stock rods and crank (ARP 5/16" rod bolts).
