200sxdatsun Posted November 23, 2007 Share Posted November 23, 2007 I know I can search, but maybe someone knows this. I'm replacing my stubs with 280zxt 6 bolts. I ordered new nuts, 27mm ones. Do you steak them or just used tread lock on them? I was going to use a impact gun on these , will that be enough torque? Plus on the 6 bolts on each side I was going to use tread lock.What is the torque for the 6 bolts on each side? Thanks Dave...... Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted November 23, 2007 Share Posted November 23, 2007 You might want to look at the drive line FAQ and do a search. The info has been posted many times. The new nuts should be the self locking kind that don't need to be steaked, fillet or otherwise. Torque specs are posted in other threads. It is a big number Quote Link to comment Share on other sites More sharing options...
200sxdatsun Posted November 23, 2007 Author Share Posted November 23, 2007 Found results looks like.... 180-240 ftlb for the nut less washer . less with the washer 25-33 ftlb for the cv's bolts and nuts with threadlock 36-43 ftlb for the drive shaft bolts Quote Link to comment Share on other sites More sharing options...
