JessZ Posted November 26, 2007 Share Posted November 26, 2007 I've been searching for the post that describes wiring a 240z tach to a '83let engine. Can someone thow me a bone here? Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted November 26, 2007 Administrators Share Posted November 26, 2007 How about a femur? Sorry I don't have that post or recall it, but I'll throw in my $.02 if it helps... I’m assuming you are installing an L28ET in your 240-Z. In that case, I “think” you just wire it as it was originally wired in the 240-Z, triggered off the positive side of the coil. Some guys have gutted their 240 tachs and installed ’75-'77 280Z tach guts in their 240 housing. These 280 Tachs trigger off the negative side of the coil. Is that the info you are looking for? Quote Link to comment Share on other sites More sharing options...
NZeder Posted November 26, 2007 Share Posted November 26, 2007 see http://forums.hybridz.org/showthread.php?t=122970 This is what I did to fix the problem - see the last post in the thread above. Quote Link to comment Share on other sites More sharing options...
JessZ Posted November 26, 2007 Author Share Posted November 26, 2007 BRAAP it seems you are correct. I found a thread on ZCAR and and it said the same thing. The problem I'm having now is this: When I fire the car the RPM needle spikes then stops reading. If I turn the ignition key while the car is running, but not so far to again trigger the starter the RPM needle will read perfectly, but when I let go of the key and it returns to the "normal" ON position the RPM needle stops again. Any thoughts? Quote Link to comment Share on other sites More sharing options...
CamH Posted November 27, 2007 Share Posted November 27, 2007 http://www.zcar.com/forums/read/1/328760/328922 I found that thread to be very helpful. Quote Link to comment Share on other sites More sharing options...
