High pressure fuel filter GM OEM retrofit.
bjhines
This is for Fuel injected systems as an alternative to the EXPENSIVE!!!($100-$150) aftermarket racing fuel filter assemblies rated for high pressure applications.
GM 3/8" fuel filter. Part number FF3504 or G481.
It uses the GM O-ringed line connections that must be adapted to fit my AN-6 lines.
It turns out that Dorman products has a repair kit on the "Help" racks that will allow adaptation to fit the AN hardware. It is part number 800-233(sending unit repair kit).
I cut the GM flared end off and adapted it to AN fittings using an Earl's 3/8" tubing to AN-6 hose connector.
Ta DA!!!! It fits and seals and the whole shebang costs less than an Aftermarket fuel filter replacement element. I can get these off the shelf at K-mart or damn near any store that carries filters.
Sometimes I am so smart I scare myself.
