JessZ Posted December 5, 2007 Share Posted December 5, 2007 I read this (http://forums.hybridz.org/showthread.php?t=127370&highlight=l28et+cam) and it still confused me a but. It seems Big-Phil had trouble adding a larger cam to his L28et, but proxlumus' larger cam worked out well. Mine is a totally stock '83et setup and I'm after a lopier exhaust note at idle. I miss the na sound of an NA L6 motor, but love the fuel injection and turbo. If this souds too superficial, I don't know, but simply put-any suggestions on cam specs to get the sound I'm after without damaging my performance on my stock setup? I was under the impression that the turbo will raise performance over the same rpm range, despite changing the cam. Am I wrong here? Quote Link to comment Share on other sites More sharing options...
nismopick Posted December 5, 2007 Share Posted December 5, 2007 If you want a larger cam just for the lopey exhaust, build an n/a motor. Turbo cams are setup different than n/a. Quote Link to comment Share on other sites More sharing options...
