datsun 1/2 dozen SD Posted December 11, 2007 Share Posted December 11, 2007 has anyone else used a mopar ignition box on there car? i just put one on just to see what happens the result is that it works great! i think this would be a cheaper alternative to an msd ignition just checking if any one else has already done it Quote Link to comment Share on other sites More sharing options...
A. G. Olphart Posted December 11, 2007 Share Posted December 11, 2007 has anyone else used a mopar ignition box on there car? i just put one on just to see what happens the result is that it works great! i think this would be a cheaper alternative to an msd ignition just checking if any one else has already done it I've used the 1970's Mopar ignition boxes to change from points to electronic on both a Toyota and a Datsun. Located magnetic pickup (reluctor) distributors for each engine, and wired the box up per an old 'Direct Connection' book. No multispark capability like MSD, but works fine. As the boxes are good for about 5000 on a V8, they should do for around 6500 on a six, or 10K on a four. Higher performance/rpm boxes are available. <> Quote Link to comment Share on other sites More sharing options...
gregkring Posted December 12, 2007 Share Posted December 12, 2007 Not really a welding issue or even a fabrication issue, but yes! very simple bucks down aproach. Available any and all hours of the night versus a MSD that could leave you stranded with no solution on a weekend. Once had a mallory HyFire die on the racecar on aFriday night after qualifications. Found an all night autostore and was ready for eliminations on Saturday morning! Greg Kring Quote Link to comment Share on other sites More sharing options...
datsun 1/2 dozen SD Posted December 12, 2007 Author Share Posted December 12, 2007 oh yeah my bad this on the wrong topic forum i was looking at alot of things all at once forgot i was on fabrication/welding my appologies Quote Link to comment Share on other sites More sharing options...
