czecho Posted December 17, 2007 Share Posted December 17, 2007 Im doing a 1uzfe build in a 1990 300zx and was just wondering what kind of tranny i should use and remember im poor and cost is a issue but i understand basic tranny costs, I going to be running 10 psi of boost eventually and need a strong tranny to hold all the power. So if you suggest a tranny can you also try to suggest where to buy them or find one. I will in SoCal if that helps at all. Thank you all for help Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted December 18, 2007 Share Posted December 18, 2007 Why not slap the Lexus transmission behind it? It would likely be the most cost effective choice. Quote Link to comment Share on other sites More sharing options...
Gareth Posted December 18, 2007 Share Posted December 18, 2007 If you'd like to run a manual tranny behind it, you're going to have to either custom make or buy a tranny adapter from Australia or New Zealand. Either way, it is going to be costly. The factory A340 auto should hold just fine around the stock power level, but there are tranny upgrades available ($$$). From what I've read on this forum, the TH400 is the strongest OEM auto tranny that you can get, but you still need an adapter. Tough choice. Quote Link to comment Share on other sites More sharing options...
Clifton Posted December 19, 2007 Share Posted December 19, 2007 There are aftermarket bell housings for the Toyota W series and R series. If you plan to turbo it and make a bunch of torque the R154 is the way to go. 1fastZ just put a 1U in a 4runner with a W series. Thing moves pretty good for a big heavy lifted truck. I lost all my links but here's a few http://www.lextreme.com/ http://www.v-eight.com/ http://www.dellowauto.com.au/main.html Quote Link to comment Share on other sites More sharing options...
TRD_240Z Posted January 1, 2008 Share Posted January 1, 2008 I would strongly recommend an R series from the MK3 turbo. A W has a greater chance of blowing out if not driven properly over 300hp, but some have proven to otherwise. Although now a days the R series is becoming much more expensive than it used to be. Just the 1jz bellhousing is $300 alone. Quote Link to comment Share on other sites More sharing options...
Clifton Posted January 2, 2008 Share Posted January 2, 2008 A W has a greater chance of blowing out if not driven properly over 300hp, but some have proven to otherwise. It's the torque, not hp that breaks things. Quote Link to comment Share on other sites More sharing options...
