TurboSouthAfrican Posted December 25, 2007 Share Posted December 25, 2007 My somewhat daily driver RB25 240SX started to, what I like to call a stutter or miss about a month ago. First only did it now and again, always seemed to start when car is fully warmed up, but has started to do it more often, even at idle you can hear small hick up in the rpm. My first thought was that it was an ignition problem of some kind. I pulled the coil packs and checked the plugs, all was fine, so I thought must be one of the coil packs. I replaced all coil packs from my other car and still does not cure the problem???? Could this be an igniter problem? Any info would be greatly appreciated, thanks. Merry Christmas to everyone by the way. Take care Larry Quote Link to comment Share on other sites More sharing options...
TurboSouthAfrican Posted December 26, 2007 Author Share Posted December 26, 2007 Anybody??? Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted December 26, 2007 Share Posted December 26, 2007 Could be an injector problem. What injectors are you using? I have a crappy set of Venom injectors in my car, and I had a somewhat consistent hiccup. I traded them in for a new set under warranty and it went away totally. This was generally after the motor warmed up. Evan Quote Link to comment Share on other sites More sharing options...
TurboSouthAfrican Posted December 26, 2007 Author Share Posted December 26, 2007 Motor is completely stock including injectors. Never had any problems and slowly but surely problem has gotten worse. Quote Link to comment Share on other sites More sharing options...
Careless Posted December 27, 2007 Share Posted December 27, 2007 heard this problem so many times on the SAU forums. Find someone who will lend you a coil plug, and swap from coil to coil, seeing if the idle persists. if it does, chances are the boot on the one that's operating sporadically is cracked or weathered and allowing the spark to arch somewhere else or is causing some bad RF freq in beyond the boots. Word has it that if you take some flexible and clear "diamond-hardness" (anyone ever see a flexible diamond ?) nail-polish and paint the most weathered areas of the boot, or if you take some RTV silicone and smear it over the affected area, you will make it work for a couple of months until the weather changes and ill effects present themselves again. some people go with the SuperDI blue coil packs, but they've been tested and shown to not produce a better spark, and in some cases worse. A good alternative is a waste-spark buick coil pack as outlined in someone elses thread here. That would produce a hotter and better spark than the standard nissan coils and would be easy to purchase as well as fit, because you could mount it on the firewall and use a set of generic magnecore 8mm plug wires or something. Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted December 27, 2007 Share Posted December 27, 2007 He already replaced all the coils. Does not matter if your injectors are stock, one could be partially plugged or going bad. Thats about all I got, from first hand experience anyway! Evan Quote Link to comment Share on other sites More sharing options...
TurboSouthAfrican Posted December 27, 2007 Author Share Posted December 27, 2007 I think it could be the igniter, are RB26 and RB25 igniter's interchangeable, I would think so, if they use the same coil packs right? Thanks again for the input. Larry Quote Link to comment Share on other sites More sharing options...
Careless Posted December 28, 2007 Share Posted December 28, 2007 oh shizz, i really should read a bit better. LOL didn't see you replaced the coils. Quote Link to comment Share on other sites More sharing options...
TurboSouthAfrican Posted December 28, 2007 Author Share Posted December 28, 2007 oh shizz, i really should read a bit better. LOLdidn't see you replaced the coils. No worries, I know you are probably half frozen up there in Canada, thanks for the help though. Have a good new years, take care. Larry Quote Link to comment Share on other sites More sharing options...
Careless Posted December 28, 2007 Share Posted December 28, 2007 I think it could be the igniter, are RB26 and RB25 igniter's interchangeable, I would think so, if they use the same coil packs right? Thanks again for the input. Larry No problem. the plugs (connectors) are different on the RB25's than they are on the RB26. And I think you can use a Z32 ignitor if you have to. Boozt3d wrote a DIY thread that should get you up and running using the Z32 ignitor =). Raff Quote Link to comment Share on other sites More sharing options...
