280zxt oil filter housing
drowz
Seeing it as the fittings for a oil cooler are already there I would take advantage of it and use it. You should be able to get Metric to SAE hose adapters at a good hydraulics shop. Then just ask them for some "push on" hose ends. Make up your own custom lines and run a oil cooler. You could even run the hoses in a closed loop for the time being if you want to hold out on getting a cooler.
If you do want to remove the system altogether, I think there is a hex that you can get a wrench onto at the base of the threaded shaft the oil filter screws on to. Of course you will need the parts from your old block to replace them with.
The sandwich plate on the Automatic ZXTs has something in it that is internal in the non-turbo or manual turbo car's block.
You need to use it, as you cannot simply replace the stud with the correct one. I believe it has a bypass valve that is otherwise cast in the other blocks.
Search on it, it's been discussed. I got the SAE adapters for mine and just have it looped, I'm waiting to mount the oil cooler till I know what my front end looks like.
Mario
On the turbo automatics, there is a blocking plug on the block within the diameter of the oil filter sealing surface for a relief valve. In all others, there is a bypass valve in the same place to keep pressure at the filter below what would explode from either overly thick oil in low temps or a clogged oil filter.
In the turbo automatics, the bypass valve is in the housing that feeds the cooler lines.
I've run without the cooler and bypass for years on my cars but you must make sure you change the oil filter before it is clogged or the pressure rises in the filter.
I prefer my oil filtered all the time rather than have it bypass and not get filtered.
