heavy85 Posted December 30, 2007 Share Posted December 30, 2007 The mounting bracket has separated from the tank on my radiator on one corner. It looks like it's just brazed on so can I just braze it back on just like I would copper water pipes? Thanks Cameron Quote Link to comment Share on other sites More sharing options...
jt1 Posted December 30, 2007 Share Posted December 30, 2007 It's soldered instead of brazed. A rad shop will just solder it back, which you can do yourself. Be careful with the heat so you don't melt solder elsewhere on the radiator and create a leak. It is sorta easy to melt the joint where the tank is soldered to the header. jt Quote Link to comment Share on other sites More sharing options...
heavy85 Posted January 1, 2008 Author Share Posted January 1, 2008 It's soldered instead of brazed. Right I knew that if I just thought about it. Brazing required a LOT higher heat ... like oxy/aceteline in my experience ... than solder. Anyway I soldered it back on so we'll see how it holds up. Thanks Cameron Quote Link to comment Share on other sites More sharing options...
