How do strut bars work ?
Guest Carlissimo
Carlo raised a good point. I ran into a bridge abutment on the freeway, right side of car. Everything on the right side of the engine was pushed back to the firewall. In my crash, with some of the bracing above, I bet the brace would have been forced into the passenger compartment if it wasn't braced from behind.
Tbuck, Carlo was right, great looking engine compartment.
Scott
Any concern about creating "spears" that may be driven into the cabin in the event of a crash
If you tie the bracing into the firewall near the hood latch, you are a good 3 feet from either seat. If that becomes an issue in a wreck, your toast anyway. But I would tie in some type of cross support just to make everything more rigid anyway.
Triangles are definitely the way to go. That design to run Y shaped pieces straight back to the firewall has been discussed before.
