T56
Guest Locutus
Guest Locutus
I found a T56 for 650 bucks, the only thing is its only the tranny, no bell housing, no clutch, pressure plate bearings, slave cylinders etc(I realize most of that is replaced new) so is it a good deal or not? it appears very clean, and he says it has 20,000 miles on it, came out of a 96 v8 camaro. how much more am I going to have to purchase to make this work with just the tranny
Bellhousing is the big issue. I'm not aware (And I hope someone else has found them...) of any company making an aftermarket BLOW PROOF bell housing. If they aren't out there, this means you will have to go to GM and buy the bellhousing from them. You shouldn't expect to get one in a salvage yard, because they won't let much go on the T56 units... the like to sell them as a complete setup...
Other than that, read my tech article and check the cost for the Pressure plate, flywheel, and hydraulic fluid mods....
Mike
mjk
