Guest Justlikemusic Posted February 3, 2008 Share Posted February 3, 2008 Hello, I am trying to find out if my 302's power steering pump is going to be compatible with the 280zx's power steering rack? I dont mind going back to having no power steering if need be the case, but wanted to know if it was just a matter of disconnecting the two hoses which currently go to my rack and then connect them up to the Zx's. Car I'm probably looking at getting now is a 82 280zx for the four wheel disc brakes, and cheap initial buy price. Also apparently chassis strength is alot better for the v8 conversions. Cheers Quote Link to comment Share on other sites More sharing options...
Gollum Posted February 4, 2008 Share Posted February 4, 2008 I can't say for a fact that it WILL work, but I do know that most power steering systems are very similar, and work with nearly identical pressures and fluids. I've seen plenty of other swaps in which people used the donor engine's pump with the car's rack without issue. Quote Link to comment Share on other sites More sharing options...
